Intel Integraded Graphics Help
Go to solution Solved by AlbertScrub,
I ran the intel driver auto detect and it is downloading some intel iris hopefully this helps
edit: wow I dont even know why i made this post you guys can laugh at me i will just be crying. its 4 in the morning to be fair
So today I had to send in my GPU and so I am left with no GPU. I have an nice locked i7 but when i try to play games such as CS.. I get kicked from CSM I am guessing it is because CS uses pixel shader 3.0 and I do not have that. but if that is true how do people use integraded graphics to play which ive seen. Is there a driver i need?
PS: omg you guys on the fourm are SO nice actually you guys are the best.
EDIT: omg im fucking retarded I didnt even put my CPU in here I have i7 4770 locked. Also I have some nivida drivers should I get rid of those or?
also if im just dumb and all i need to do is be good at googleing tell me
https://linustechtips.com/topic/301520-intel-integraded-graphics-help/
What is "CSM"? Counter-Strike...?
Anyways, it should have Pixel Shader 3.0 already. You can update the Intel drivers, but beware, their drivers are currently messed up for gaming. They have serious automatic, unchangeable scaling issues in a majority of games.
http://www.intel.com/support/graphics/sb/CS-033757.htm
hm I will keep googling
Quote from a intel REP.
Actually, the Intel HD Graphics supports shader model 4.0, this is enabled after you install the latest graphics driver.
you probably dont have the driver for it.
Like i said you didn't have the driver ;)
