Just updated my BIOS and now seeing 80 on the debug LED on the motherboard. Has been showing A0 before the update. I've Googled for info but found nothing related to my Z87 Pro board. Any of you guys know what the 80 code means?
Thanks!
Interesting... your manual doesn't have Q-codes.
For my Z97 Maximus VII Gene code B0 (80) is "Runtime Set Virtual Address Map Begin"
Does your computer boot?  If your computer is operating normally, then I wouldn't worry too much about it.
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
https://linustechtips.com/topic/301442-asus-z87-pro-q-code-80/#findComment-4097066
Yes, the manual for my motherboard has a listing of Q-codes, just not showing what the 80 code means. After a little more searching on the web, I've seen others saying it has something to do with ASUS' AI Suite software, but this was for different motherboards than mine. I guess it could still mean the same for me. I just booted up my pc and am showing the A0 code, which is what I've always seen and is the normal code to be seeing. I guess the 80 code is no big deal. Just wanted to know what it was as it's not listed in my manual.
Thanks.
https://linustechtips.com/topic/301442-asus-z87-pro-q-code-80/#findComment-4099420
