Hey guys every time i install these two rain-meter skins:
http://rainmeterhub.com/skins/honeycomb/
http://rainmeterhub.com/skins/mini-steam-launcher/
i refresh rain meter and nothing happens, how do i install them??
~Elias
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/300957-help-installing-rainmeter-skins/
Never really used Rainmeter, when I did I had some trouble with skins, so I'd also like to know.
Also, second link is broken. And follow your topic dammit! @melias24
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
The file with .rmskin extension, you just double click it in order to install it
If it comes with .rar and .zip archive, extract that folder into the Rainmeter skin folder in the My Documents (I believe)
There is a subreddit dedicated to rainmeter with tutorial in there http://www.reddit.com/r/Rainmeter/ I would recommend checking it out.
I have rainmeter and it is awesome but I installed it a while ago and I forgot how to install skins but everything that you need or tutorial is in the subreddit.
cpu:I7 4770k @ 4.3   gpu: 3.5 gb ( ͡° ͜ʖ ͡°) GTX 970 @ 1530MHZ   Ram: 16Gb
