Right now, my Intel Core i7-4790k is cooled by the stock cooler, but when I play, it gets very hot (72 degrees celsius). I'm considering upgrading to the corsair hydro h100i, but when I remove the stock cooler will there be thermal paste left on the cpu? if yes, do I need to remove it first, and with what do I do so?
Case: Antec Twelve Hundred V3 | Motherboard: ASUS Maximus VII Hero | CPU: Intel Core i7-4790k @ 4.4GHz | RAM: G. Skill RipjawsX DDR3-2133 MHz C9 QC - 16GB | GPU: GIGABYTE GeForce GTX 980 G1 Gaming | PSU: Corsair AX860 | SSD: 2x Samsung 840 EVO SSD's in RAID 0
https://linustechtips.com/topic/300459-changing-cooler/
Is there some sort of specific alcohol I should use/avoid? Is the pre applied paste good enough, or should I buy some other paste?
https://linustechtips.com/topic/300459-changing-cooler/#findComment-4081568
just use some high-percentage stuff.
https://linustechtips.com/topic/300459-changing-cooler/#findComment-4081590
