Need help with iTunes
Solved by Pomfinator,
iTunes has never supported the Matroska container. The best option is to download a seperate app. nPlayer is my recommendation, a lot of the other ones are shady or have ads all over them. I would suggest VLC, but that's in limbo ATM b/c iOS8 fked everything up. These apps will allow you to add files in the App section of the device area when you plug in you stuff.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
4
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods14
play_circle_filled
Latest From ShortCircuit:
