I got a lot of hard ache for not using pcpartpicker.com so i decided if was going to get the best help needed i would need to repost this topic
but the two questions sill stand
Will everything fit (mainly the Ram and CPU cooler.)
And can i make any small improvements over what i picked
 https://pcpartpicker.com/user/Fringedabyss97/saved/#savedbuild_1955440
Again thanks for the help Love the forums!
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/
Everything should fit. The 212 evo isnt big enough to hit the ram so its fine.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/#findComment-4076109
Seems like a pretty good build to me :)
Although is that the ssd (thanks harrynowl) that had kingstons sneaky nand swap fisaco?
I believe that cooler and ram should fit, after a quick google search :P
Welcome to the forums, glad to hear you like it!
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/#findComment-4076133
Although is that the ram that had kingstons sneaky nand swap fisaco?
SSD you mean? But yes it was.
I'd grab a 4690K and a cheaper Z97 based board though, but it's not bad by any means.
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/#findComment-4076157
 Yep, thanks. Is it still worth getting?
Only if it's significantly cheaper than the other options, the slowest SSD is still going to be much faster than a hard drive.
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/#findComment-4076211
Also i know the motherboard is a little expensive but i love the color and it has what i need
What about the MSI Z97 Gaming 3/5 and the Gigabyte Z97 Gaming?
They follow the red/black scheme and offer the same features.
https://linustechtips.com/topic/300087-my-first-pc-build-pt-2/#findComment-4076216
