Hi LLT community!
I just built a pc and I need some help. I am fairly new with the forums, and I would like some information on what kind of dirvers or upgrades I should get for my computer. here is my build :
  1 x Intel Core i5 4690K Unlocked Quad Core 3.5GHZ/3.9GHZ Processor LGA1150 Haswell 6MB Cache Retail
  1 x Corsair Cooling Hydro Series H60 *NCIX PC Only*
  1 x ASUS Z97-E ATX LGA1150 DDR3 2PCI-E16 3PCI-E1 2PCI CrossFireX/SLI SATA3 USB3.0 DVI HDMI Motherboard
  1 x Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit for NCIX PC
  1 x EVGA GeForce GTX970 Superclocked ACX 2.0 4GB NCIX PC Only *OEM*
  1 x Corsair Carbide Series 230T Window Black Gaming Case ATX 3X5.25 4X3.5 Front USB3.0 Audio for NCIX PC
  1 x Corsair CX Series CX750M 750W ATX 12V 80 Plus Bronze Modular Power Supply
  1 x Microsoft Windows 8.1 64Bit English DVD OEM for NCIX PC
  1 x Kingston HyperX Fury 120GB SSD SATA3 SandForce SF2281 2.5in 7MM Solid Stat Disk Drive Bulk
  1 x Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps 3.5in Internal Hard Drive - OEM
  1 x ASUS DRW-24F1ST 24X SATA DVD Writer Black
  1 x PC Assembly and Testing With 1 Year Limited NCIX System Warranty PRE-CONFIG WIN. OS If Purchased
What drivers will I need for computer? As i don't have enough money for NCIX to assemble it for me, I'll be installing windows and the drivers myself.
Please help, and thank you in advanced!
https://linustechtips.com/topic/300011-help-with-my-build/
ALthough not needed it is worth it for upgrade. Great build man. However I would downgrade psu and bump up to some good ram
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/300011-help-with-my-build/#findComment-4075005
