recording audio software
Go to solution Solved by Wtalk2,
Would Audacity suffice for what you need?
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
https://linustechtips.com/topic/299640-recording-audio-software/#findComment-4069406
If you ever decide that you need more advanced functionality then Audacity can give you, I'd highly recommend giving Reaper a try. I don't work for them or anything, it's just a great piece of software and I've pretty much exclusively used it for recording, editing, and mixing music for the last three+ years. Paid software, but unlimited free trial.
https://linustechtips.com/topic/299640-recording-audio-software/#findComment-4069601
