most likely not a easy fix (meaning most likely you cant do it yourself)
https://linustechtips.com/topic/298207-easy-fix-or-not/#findComment-4047808
The image
you broke the screen ,there are replacements on the internet but I would just send it in for repair.
https://linustechtips.com/topic/298207-easy-fix-or-not/#findComment-4047826
