http://tinypic.com/r/b5obgo/8
The lights that flash red when I turn on the PC seem to be (according to the manual) the:
DRAM LED
VGA LED
BOOT DEVICE LED
And possibly the CPU LED, but I can't see it from under the heatsink...
Please help, I've spent like 10 hours trying to build this and idk what to do now.
Thanks a lot.
https://linustechtips.com/topic/297625-please-help/
DRAM LED
VGA LED
BOOT DEVICE LED
Thanks a lot.
When the lights flash that means it is POSTing fine, as soon as it holds on a light on a specific area there is your problem.
It seems to be holding red on your GPU have you correctly socketed it in to the lane are all the power cables plugged in correctly?
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
https://linustechtips.com/topic/297625-please-help/#findComment-4040349
I had to use the second PCIexpress x16 slot because the CPU cooler was covering the first one... Maybe that's the issue? I think the power cables are connected correctly. My PSU has a 6 and 2 PCIe connector which I plugged into the 8 slots on the GTX 970 Strix you see there... And yes I'm pretty sure it's in properly O.o.
https://linustechtips.com/topic/297625-please-help/#findComment-4040364
@Zuzu
do you have onboard graphics? if so try use them to post with out plugging in the GPU
Custom Water Loop
https://linustechtips.com/topic/297625-please-help/#findComment-4040375
The case fans are all working, but not sure about anything else.
sometimes if they are not aligned properly they can cause a no post issues. they may look like they are right but the 4 pin on your 24 pin could be a bit off
also check your ram and reset you bios
plus what are the specs?
https://linustechtips.com/topic/297625-please-help/#findComment-4040382
plus that is the specs?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($326.95 @ SuperBiiz)
Motherboard: Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard  ($203.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($332.50 @ Directron)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($108.99 @ SuperBiiz)
Total: $1509.31
Generated by PCPartPicker 2015-01-24 20:15 EST-0500
And just the NZXT case fans that came pre-installed. I don't have any case fans connected to the motherboard. I'm just using a molex to the PSU from the inbuilt fan hub inside the case.
https://linustechtips.com/topic/297625-please-help/#findComment-4040399
