I need serious help with grounding a PSU to Mains.
Solved by shanky887614,
not all of europe uses the shuko socket that you are thinking of.on euro sockets the grounding pins are on the side so it will still go in
the french,german and swiss are all different.
the uk's bs 1363 is different agan.
you should be able to buy an iec lead with your local plug on the end or make one yourself
Featured Topics
XxWOODSIExX ·
Posted in Troubleshooting2 -
Pove ·
Posted in New Builds and Planning7 -
4
tommmie20000 ·
Posted in Audio3 -
INotPablo ·
Posted in Cases and Mods2 -
Pove ·
Posted in Power Supplies6 -
Knugen1015 ·
Posted in Windows3 -
1
2
2
