Hey guys,
I decided it was time to upgrade my pc and I am interested in water cooling. I would just like some advice and your opinion on my choice.
Build as of now :
case: Phanteks enthoo pro (not bought yet)
Mb: Gigabyet z97x-Gaming 3
cpu: i7 4770k 3.5 GHz
Gpu: Gtx 780 ti
I'm planing on overclocking
For the water cooling I was looking at XSPC kits, with a EX420 radiator and a 750 bay res/pump combo.
Do you know if that case can support the 750 reservoir?
I'am also considering a cylindrical res/pump instead of the bay reservoir.
The other thing I'd like to know is the best combination for pump and reservoir for the noise level since I'm aiming for as low as possible.
Thanks in advance!
Here's a quick setup for my loop.
https://linustechtips.com/topic/296760-first-time-watercooling/
