PCPartPicker part list: http://pcpartpicker.com/p/TjGYhM
Price breakdown by merchant: http://pcpartpicker.com/p/TjGYhM/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($215.98 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($88.98 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($125.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory ($66.99 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Drive ($197.89 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB Video Card ($352.19 @ Amazon)
Case: NZXT Phantom 240 ATX Mid Tower Case ($66.99 @ Directron)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($64.99 @ NCIX US)
Total: $1180.00
Generated by PCPartPicker
What do you think?
What monitor you recommend?(~200e)
Java Programmer, AMD Fanboy and soon to be casemodder
https://linustechtips.com/topic/296748-build-for-a-friend/
@Sklo
Check out the latest news re. the memory issues discovered with the 970 (you might want to go Radeon) but otherwise, pretty nice (although personally I might save some cash on the memory but that's me).
Edit: @Sklo Also, look into the memory controller on the board and see if you can split the sticks without causing memory controller issues. As far as I know it's still better to have two sticks rather than one (and that should theoretically give you better performance). Four sticks can cause memory controller strain but I believe that's being eliminated these days, so depending on the board you might be better off splitting the sticks (If you're only building it for gaming you'll probably never max out 8Gig before the entire system needs replacing anyway (you only really need massive amounts of RAM for video processing etc. games are much less demanding))
"I try to put good out into the world...that way I can believe it's out there." --CKN                  “How people treat you is their karma; how you react is yours.” --Wayne Dyer
[Needs Updating] My PC: i5-10600K @TBD / 32GB DDR4 @4000MHz / Z490 AORUS Elite AC / Titan RTX / Samsung 1TB 960 Evo / EVGA SuperNova 850 T2
https://linustechtips.com/topic/296748-build-for-a-friend/#findComment-4028218
@Sklo There is little point buying an h100i if you are not going to buy an overclock able cpu e.g. i5 4690K
thanks
I would get a 1tb HDD to go along with that, 256 gb don't last very long...Otherwise nice build :)
would liek to have at least 2tb, what would yous rec?
https://linustechtips.com/topic/296748-build-for-a-friend/#findComment-4028251
Total: $1180.00
What do you think?
If you're going for a non-k processor, get an H97 board instead.  It will save you money.  Also, I'd go with 2x4GB instead of 1x8GB so you can make use of dual-channel memory.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/296748-build-for-a-friend/#findComment-4028291
thanks
Just check whatever's on sale at your pc shop/website. I know a lot of people feel very strongly about which HDD's to use and which not to use but personally I've never had one fail on me and I've usually just gone with cheapest from brands that I actually recognize. So as long as they are just for normal use check their sales. We'll all be upgrading to ssd's in a few years anyways *crosses fingers and wishes upon a star*
https://linustechtips.com/topic/296748-build-for-a-friend/#findComment-4030154
