max Voltage for 770
Go to solution Solved by NeatSquidYT,
Yep, just keep an eye on the temps and you're fine. Voltage can't kill a GPU, temps can.
As you may know by now, I'am playing around with my 770 a bit and try to OC that GPU a bit, after some fun I would like to increase the Voltage now because I only gained about 80MHz more or so stable without. I read that the Voltage is ok as long as the Temp is fine, is this correct ? If not whats the max I should get (just roughly kinda scared of breaking that card).
Thanks ahead
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/296739-max-voltage-for-770/
Thanks for the answer, will send you the fried card otherwise :P
https://linustechtips.com/topic/296739-max-voltage-for-770/#findComment-4028131
