none, i will use intel hd
ok but what is the brand of the PSU?
do not cheap on that, coz it will be a pain if the PSU blows and takes the whole PC with it
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/296607-budge-build-question/#findComment-4026246
meh, I don't know how demanding dota is but I can't say much for the pentium
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/296607-budge-build-question/#findComment-4026249
planning to buy from corsair.
pick the CX430 gen 2 or 3 which has a larger 12volt power and uses the 8 pin PCI-E
then you can add a GPU later
https://linustechtips.com/topic/296607-budge-build-question/#findComment-4026265
okay, but in this current build, it's okay for gaming dota 2?
ok for dota but def not for multi tasking
https://linustechtips.com/topic/296607-budge-build-question/#findComment-4026289
