I'm planning on getting LED strips to put in my case. I want your opinions on 3 things:
- How long should the strips be?
- What colour?
- I plan on getting 2 strips, bottom and top of the case. Or is 1 strip in the bottom enough?
This is the case i have:
http://www.corsair.com/en-in/graphite-series-230t-windowed-compact-mid-tower-case-rebel-orange
I live in Belgium.
https://linustechtips.com/topic/295199-led-strips/
Around 20 cm
Orange/Red
2 strips
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/295199-led-strips/#findComment-4007554
I have one LED Strip, 80cm long and it goes from the back side to the bottom, that is enough... Color? depends... but i recommend white, because normal colors kill the color scheme... Picture a blue oriented build with blue LEDs... the components would be completely "eaten" with the blue light and the color would not be that pronounced
https://linustechtips.com/topic/295199-led-strips/#findComment-4007561
Do you want to have your entire case lit or just your window?
Length: Case: 50cm, Window: 20cm
Color: Orange would be the best choice here I think.
Amount: I suggest a strip at the top and one at the bottom.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/295199-led-strips/#findComment-4007562
The others are saying red/orange. I was thinking about those colours but what you are saying makes sense too :P damn this makes it even more difficult.
I think i'll go with 2 leds of 20 cm each. Just the colour now!
https://linustechtips.com/topic/295199-led-strips/#findComment-4007601
I know what I am talking about, I used to have it just like that in my old rig :D blue scheme+blue LEDs... I dun goof'd
https://linustechtips.com/topic/295199-led-strips/#findComment-4007614
