Hey everyone, I am looking to run SLI 780's and I found this great deal on newegg and want to buy it http://www.newegg.com/Product/Product.aspx?Item=N82E16814133548&cm_re=PNY_780-_-14-133-548-_-Product.   my problem is that I currently have a GTX 780 SC and I am wondering if anyone can tell me for sure that this card is going to be able to SLI with the EVGA card?
Thank you for the help,
Josh
https://linustechtips.com/topic/294960-sli-help/
You can SLI those 2 cards, brand doesn't matter for sli
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/294960-sli-help/#findComment-4004510
How DARE you even consider SLI'ing 2 different GPU Coolers together. Do you know bad that'd look.
All good, it'll work.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/294960-sli-help/#findComment-4004574
Thanks guys!  Haha the coolers don't matter it is going to be part of a bigger water cooling rig.
https://linustechtips.com/topic/294960-sli-help/#findComment-4004617
