Hello,
I'm looking into building a gaming desktop. I am mostly going to use it for WoW but I'll also be playing some DCS, AC and CoD. After doing some research, I found out that a game like WoW benefits more from a better CPU. So I've come up with this build and I'd like to hear your opinions. ( My maximum budget is 700€-800€ )
CPU - i5 4690k
mobo - Gigabyte H97M-HD3
GPU - Gigabyte GeForce GTX 760
RAM - 8GB Kingston HyperX Fury DDR3 - 1866Mhz
PSU - Corsair Builder Series CX500 80plus
SSD - of some sort to run the OS
HDD - of some sort to keep movies etc
I'm looking forward to your replies.
https://linustechtips.com/topic/294777-need-help-building-a-gaming-pc/
You are buying a OCable CPU with a non OCable Motherboard, get the i5 4690, or a Z97 Board
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
Looks awesome. Now you just need a casing to put all those in. If you are going into OC it at some point of time, might want to consider watercooling be it a custom loop or AIO.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
