Tbh temperatures wont be a problem on a 970 so its not really that important.
Power limit max, voltage max (+87 mV), +100 MHz core +400 MHz memory is where i would start
You shouldnt really be worried, overclocking a 970 is easy as hell. You cant really fry a 970 without a custom BIOS
Increase core and memory frequency and you generally don't want it to get to 90 degrees but 80-85 is fine
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
