Laptop help
Go to solution Solved by ZetZet,
What can i do about it then. BTW i have bluetooth to maybe thats one of the antennas
You need a better wireless card, this one is pretty good
http://www.amazon.com/Intel-Dual-Band-Wireless-AC-Bluetooth/dp/B00E7QGHE6/ref=sr_1_2?ie=UTF8&qid=1421694410&sr=8-2&keywords=7260
I have a HP Probook 430 g2. Before you say its bad. i know, but its for school and it's good enough and has a ssd.
The problem is unreliable internet and overheating. but i think the overheating is just it being an HP.
I have the I7-5500 u model. the main problem is unreliable internet.
https://linustechtips.com/topic/294100-laptop-help/
430 g2 is pretty good for the price.
overheathing is not something easy to fix, unreliable internet is a common problem, you have to upgrade you network adapter, but it only has one antenna which is not good, i don't even know if you can upgrade it.
http://www.notebookcheck.net/HP-ProBook-430-G2-Notebook-Review-Update.133577.0.html
https://linustechtips.com/topic/294100-laptop-help/#findComment-3993315
Is this the network card. http://imgur.com/NCjFSsU
https://linustechtips.com/topic/294100-laptop-help/#findComment-3993390
Yes. It turns out you got the dual antenna version.
https://linustechtips.com/topic/294100-laptop-help/#findComment-3993398
https://linustechtips.com/topic/294100-laptop-help/#findComment-3993427
