Would this work?
WHITENERGY 5050 30LED/m 5m
http://ipon.hu/webshop/product/whitenergy_5050_30led_m_5m_kek_06996/301991
If yes, what else do I need? Some PSU designed for it? Any controllers to change color or...? :S
If not, could you recommend high quality PC led strips?
https://linustechtips.com/topic/293605-led-inside-case-question/
Hahaha, well this isn't per say designed for any PSU.  It's 12V, so it will work with any, you'll just need to fashion it into a connector to plug with your PSU is all.
Cannot change the color, you'll need different colored LEDs for that.
Try Bitfenix Alchemy LED Strips, more expensive, but have the connector already, and pretty reasonable lengths for PCs
https://linustechtips.com/topic/293605-led-inside-case-question/#findComment-3986418
The NZXT LED Strips are really good
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/293605-led-inside-case-question/#findComment-3986420
the led strips you showed are generally used for decorative lighting like under a hanging clouset. they work very well if you use them for what they're designed for: being plugged into 12V, and produce light. dont expect much else from them, but if thats what you need go ahead and buy some, just shove the wires in a spare molex (because those are still necessary these days...) and you're good to go.
sidenote: put them where you cant see them directly, they are ugly as hell.
https://linustechtips.com/topic/293605-led-inside-case-question/#findComment-3986485
