why do i need a fan controller if they are just going to run the whole time dont i just plug them into my mobo
Your mobo doesn't have enough connectors.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3984441
how many does it have?
I'm pretty sure it only has a CPU fan connector. Most mobos only have that. Other fans are connected through a SATA fancontroller which is built in to your case, or through a fan controller, and some PSU's have fan connectors as well.
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3984826
Spectres aren't that quiet. If you want quiet led fans, get Gelid Wings instead.
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3985414
so is this a much better build will it be quieter and is there anything i am missing?
http://pcpartpicker.com/p/HsBy99
Not really.. Those aren't Gelid Wings.
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3985784
but didnt linus say these fans are good? i dont need light up ones i just though corsair made good fans
They're .. okay. Corsair fans range from bad to alright/pretty good. Gelid Wings are better and are the fans Linus uses in his personal rig.
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3985943
so which case should i get? which one is the best for building a silent system
If quiet is your goal, just get a Silent Base 800 and stick with the stock case fans unless you don't mind getting another case only to replace the fans with more expensive Noctuas/SilentWings2's.
https://linustechtips.com/topic/293429-how-many-fans/#findComment-3986121
