Hello iam new to this forum so please excuse if this post/topic is in the wrong area.
I have resonantly built my first pc and i have noticed a horrible chemical smell coming from the psu.
i looked though the grates and found that some glue had melted
i have put a desk fan near it to keep it cool and stop the smell.
i want to know if i should get a new better psu or will it be ok to use like it is?
psu= Artic red+ silent (yes i know this is very cheap)
Thanks in advance!
https://linustechtips.com/topic/293249-need-help-with-my-psu/
You have bought an off-brand PSU. Stop using your pc right now before that PSU fries a component.
Get a better PSU. Give us your system specs and budget and we'll give you the appropriate PSU to buy
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/293249-need-help-with-my-psu/#findComment-3981825
AMD fx 8150
AMD radeon r9 270x
ASROCK 970 extreme3
1TB and 500GB HDD'S
Gelid solutuions cpu cooler
couple of case fans
oh and £50-75
Budget?
Edit: Oh I see now, Corsair CS550M is a great choice for a PSU
https://linustechtips.com/topic/293249-need-help-with-my-psu/#findComment-3981854
