Help with system instability
Go to solution Solved by TDP_Equinox,
Yes it does have dual bios.
Try swapping to the other one.
Hoping someone can help! Having stability probs. Random software crashes, especially web browsers, Chrome, Firefox, and IE. Other programs crash too. My Sound card disappears until I reinstall its drivers. I switched to onboard audio for now. Sometimes booting into Windows my USB keyboard won't work until I reboot. ive had occasional complete system freeze.
I've tried formatting & reinstalling. All stock settings, no overclocking or even turbo mode. I've tried different RAM. All drivers and firmware are up-to-date. I've disabled browser add-ons with no luck. I've also tried mem test with no issues.
Any suggestions are appreciated!
Windows 7 professional 64 bit
MSI Z77 MPower
I7 3770K
MSI GeForce 660 TI
Boot Drive: Intel 730 480 GB SSD
Seagate 2 TB storage drive
Patriot Viper 16 GB RAM
Seasonic M12D 750 W PSU
Edited by Bronn
https://linustechtips.com/topic/292350-help-with-system-instability/
Try resetting your BIOS, and if that doesn't work, update it.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
I have reset bios. There are no new bios updates. I had a sound blaster x-fi titanium hd but just recently removed it.
Does your mobo have a dual BIOS?
Check event viewer and see if Windows can give you any insight into the issue. Try to check right after a crash so everything will be under the with in last hour tab of event viewer. If you need to know how to get to event viewer hit start, type event viewer. Normally the ones under critical and error are the helpful ones. ignore the rest.
 having multiple soundd rivers installed can do harm........ the internet related stuff....... update flash player. STOP running ( uninstall chrome ).........firefox........ load up on add blockers software/ghost/ browse security add ons.
the BIOS thing..... I mentioned battery ( replacing ) a bad battery could cause some of the problems..... new board or not. also, if you reset the BIOS and you had problems with the usb it can be a normal thing. the usb's need to be enabled for them to work..... therefore a usb/ps2 adapter very handy device.
This seems to have stopped the crashes. Haven't had one since switching. I'll continue to test it out & let you know for sure.
Good news!
Gonna mark this one solved! Still no crashes so far, fingers crossed that it's good now. Thanks for all the suggestions.
Thank you for marking as solved lol, you have no idea how many times i have posted "Mark topic as solved please" xD
  • 2 weeks later...
I'm back again! I'm still having similar problems although not as severe. I realized that in swapping the BIOS it reverted back to eight updates ago. As in there are eight newer BIOS updates than what is currently installed. I currently have version 17.4 and the latest one is 17.12.
My Internet Explorer still crashes occasionally especially if I'm using my Dragon naturally speaking software. My Dragon software also crashes occasionally. And accessing my storage drives and copying files from one to the other is very slow. Should I attempt each newer BIOS and see what happens? Or just jump to the newest one? Could there be a defect with the motherboard? I'm pretty sure I still have one year warranty left on it?
Have you tested the hard drives? Do that before messing with the BIOS.
Yes hdd's have been tested with no errors. The slowness just started after the bios swap. I've also noticed sometimes using both front usb 3 slots at the same time one will constantly disconnect and reconnect every 5 or 10 seconds. This system has been buggy since I got it. Little weird random things.
I'd say go ahead and try updating the bios, one version at a time.
Well I attempted updating the bios One version at a time via usb stick in the bios menu. I got to version 7 and the updater stopped working. I tried going to version 8 but instead updating, it just instantly rebooted. All attempts with any of the newer versions did the same thing, so I updated to the newest version using MSI live update in Windows & still have the software crashes same as before.
uninstall chrome.
skype too if you are using it.
uninstall the sound card and drivers.
unistall the sound drivers from nvidia.
under clock the gpu (ram and gpu )( not system ram )
disconnect all but main drive.
reset cmos.
go to windows updates.... install/install/install........ then go back and install some more.
