PCPartPicker part list: http://uk.pcpartpicker.com/p/bz2F3C
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For £180.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (Purchased For £25.00)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  (Purchased For £130.00)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory  (Purchased For £80.00)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (Purchased For £76.00)
Storage: Western Digital Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive  (Purchased For £0.00)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (Purchased For £266.00)
Case: Phanteks Enthoo Pro ATX Full Tower Case  (Purchased For £100.00)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  (Purchased For £50.00)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (Purchased For £70.00)
Monitor: BenQ GW2760HS 60Hz 27.0" Monitor  (£0.00)
Other: corsair k70 rgb (£0.00)
Other: corsair m65 rgb (£0.00)
Total: £977.00
Generated by PCPartPicker 2015-01-14 15:57 GMT+0000
i dont have an anti static band so how do i ground my self
thanks
https://linustechtips.com/topic/290814-starting-new-build-help/
To ground yourself when putting it together just install the power supply last. While its sitting outside of the case you can touch it every few minutes to discharge any buildup. This is assuming that the power supply housing is metal though.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
https://linustechtips.com/topic/290814-starting-new-build-help/#findComment-3948885
should it be plugged in to the wall
https://linustechtips.com/topic/290814-starting-new-build-help/#findComment-3948907
