I woulddd imagineeee that the equalizer goes before the receiver, though as Lauen said, without seeing the backs completely clueless.
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3944119
Can you show us the back ends of the units?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3944210
Depends on the plugs on the back of them
yes, here is the back end.
post-42927-0-20249900-1421196100_thumb.j
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3944478
We need to see the backs of both units, not just one unir
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3944486
I'm pretty sure that if you use HDMI you can't use the RCA out at the same time. (on the bluray)
So then you wouldn't be able to go through the equalizer, which I assume you could use with an RCA to 3,5mm with a 6,3mm adapter (or maybe an RCA to 6,3mm cable but I haven't seen those)
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3945457
To further clarify, the equalizer is a middle-man. You send audio to it, then it does the "equalization", then sends the audio out again, "equalized". The weird plugs you see are XLR ports, and the other ones are 6,3 mm ones. XLR is mostly used in more professional environments, while the 6,3 is a normal consumer thing, just the big brother to 3,5mm.
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3946706
So which wire would he need to connect the equalizer to the receiver ?
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3952840
Well you need source audio in to the equalizer, and then from equalizer to audio in on amp. RCA to 6,3mm jack (or 3,5mm with a 6,3mm adapter) in to the equalizer, and the same out. You could also use the XLR connectors with adapters to either 3,5mm, RCA or 6,3mm. the RCA to 6,3mm would probably be the cheaper option, and it most likely will sound exactly the same.
https://linustechtips.com/topic/290465-equalizer-to-av-receiver/#findComment-3955789
