https://linustechtips.com/topic/29045-coolant/#findComment-369285
How far down in the link?
https://linustechtips.com/topic/29045-coolant/#findComment-369299
Mayhem's coolants are temperamental at best. You need to be picky with your tubing if you use them, etc.
If you plan to make a gold colour yourself you should contact Mayhems on Facebook. They tend to answer within 24 hours and usually within an hour if you contact them during UK daytime.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/29045-coolant/#findComment-369344
