Hi :) my computer keeps beeping 6 times and no picture pops up but im on that same computer right now sometimes when i plug in a another keyboard it will not 6 beep and have a picture i looked up the beep codes for my computer which is a
Gateway DX4870-UB2B
6 beeps for that computer means "keyboard controller error" but how is that when my computer is on right now and im typing with that keyboard (usb not ps2) can spmeone help me? :/ i cant restart my comp or it will 6 beep lmao
(edit the other keyboard I use to make the computer not 6 beep is broken xD im confused ._ . )
https://linustechtips.com/topic/289915-computer-problem-plz-help/
I know this may sound silly But could you check your internal hardware? check if the cables are plugged in correctly? their may be something loose. I don't really know what 6 beeps mean but Try to check if your ram is placed correctly
CPU: I5 7400 | Motherboard: MSI H110M  | RAM: 16GB G-Skill 2400mhz  | GPU:  NVIDIA  MSI Gaming 4G GTX 970 | Case: Tecware Quad | Cooling: Stock| Storage: Kingston 120gb SSD, 1TB Drive ,  | PSU: Seasonic 620 Watt 80+ Bronze Full Modular | Display: Devant 50 Inch Smart TV   |
i checked all that many times already :/
sounds like a broken Super I/O Controller chip, does a ps2 keyboard work in the pc?
if not you might have to live with the beeping for the rest of life of the pc or unplug the motherboard speaker if you think the beeping is annoying
8d2064aaa80504b2674052686523f157d1eed2bd
Helpful optimist by day, Troll by night
Every second video I unsub from Linus cos he tells me to hit the subscribe button on each video!!!
xD  i guess my comp must stay on forever!!!!!! :P
Instead of buying a new keyboard, have you tried using a USB to PS/2 adapter? You can usually get one for less than a £/$. Although if the Super I/O chip is damaged like BananaNinja suggests then it may still give the error code, but it's worth a shot.
And also, does the keyboard actually still work? And can you get into the BIOS with it? If so then that sounds more like a configuration error than a problem with hardware.
CPU: Core i5 2500K @ 4.5GHz | MB: Gigabyte Z68XP-UD3P | RAM: 16GB Kingston HyperX @ 1866MHz | GPU: XFX DD R9 390 | Case: Fractal Design Define S | Storage: 500GB Samsung 850 EVO + WD Caviar Blue 500GB | PSU: Corsair RM650x | Soundcard: Creative Soundblaster X-Fi Titanium
Click here to help feed our lasses Pokemon
