Hello. I am slightly overclocking my Intel i7 4790k and I was wondering if 50-60 degrees celcius under load is ok. Thanks!
what is your overclock and what is your cooler
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/288848-intel-i7-4790k-temps/#findComment-3921468
I am using a Corsair h100i, and I'm running 4.7Ghz at max 65 degrees.
sounds fine
1
https://linustechtips.com/topic/288848-intel-i7-4790k-temps/#findComment-3921499
What would be the highest temperature I should go for?
dont go above 80 degrees
1
https://linustechtips.com/topic/288848-intel-i7-4790k-temps/#findComment-3921514
I'm running 4,6Ghz at max 63 degrees at 1.10V with H110.
Are these temps ok?
Intel I9 7900X , Gigabyte X299 Aorus gaming 9, Gibabyte Geforce GTX 1070 8GB G1 Gaming ,G Skill ripjawsV 32GB 3200 MHZ, Samsung 850 Evo 500GB ,External WD 640GB, 2 x WD 1 TB Blue, Evga Supernova 750 G2, Logitech Z5500, Gigabyte Aivia Osmium, Logitech G502 Proteus Core, Corsair 750D Full Tower, Corsair H110, Asus VS248H 24", Asus VG245HE 24".
https://linustechtips.com/topic/288848-intel-i7-4790k-temps/#findComment-3933703
