So i got myself a 7950 and decided to overclock it by a bit, to 930 mhz. However, when i rebooted my computer, a negative image is posted, like all the colours are messed up, but a reboot helped it get back to normal, and so did the clock speed. I was using GPU tweak. Now I dare not oc it again in fear of it going all wrong again.  :wub: help?
RAWR signature became a bunch of HTML codes
https://linustechtips.com/topic/28881-7950-overclocking-help/
Have you tried Msi Afterburner? It's a cinch to use.
https://linustechtips.com/topic/28881-7950-overclocking-help/#findComment-367318
Aren't they the same thing?
EDIT: same as in used for the same thing
Yep. Msi Afterburner is wayy easier to use though.
https://linustechtips.com/topic/28881-7950-overclocking-help/#findComment-368911
