anyone have problems with BF4 mutliplayer?
I just played before, it worked fine. What kind of message do you get when the game crashes? You can always try to repair the installation.
says battlefield 4 has stopped working then asks me to close the program. weird thing is when i get into the server the graphics are super low for some reason with no sound
Soon as you get into the server , the game is still loading the map and everything around it.
That's normal as I also experience that.
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
Maybe unstable GPU overclock?
Try another driver version. Max Payne 3 for example crashes with AMD's latest Omega driver, but works fine with the previous driver version.
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
