depends. for my 220mhz core clock on my 980 i have 6 volts extra
https://linustechtips.com/topic/288642-how-much-voltage-to-add/#findComment-3918884
So lets say in evga precision x, you just added 6mV to the core?
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/288642-how-much-voltage-to-add/#findComment-3918902
Unless the card is watercooled, I would not suggest adding any volatge.
When I added voltage to my GPU in MSI AB, I couldn't really overclock it any higher.
Install a custom BIOS onto your GPU if you REALLY wanna add voltage.
Be careful though. Still wouldn't recommend it.
Just max out the TDP.
blackshades on
https://linustechtips.com/topic/288642-how-much-voltage-to-add/#findComment-3918909
yes. my precision for example
https://linustechtips.com/topic/288642-how-much-voltage-to-add/#findComment-3918913
