Hi,
I am going to be building a PC soon. Please could you advise me. I am either going to get an 8350, with a good motherboard, or an 4670 with an alright motherboard. What do you think is best, and are there any other good options. You can also advise on a better build. My budget is ~£750-£800. All ill be doing is gaming. I'd linke to get +60fps on most games at ultra. Any systems that could achieve 60 fps and cheaper would be fantastic
Here is the rest of the build:
AMD R9 290
600W PSU
1TB HDD
8GB 1866MHz RAM
DVD Drive
Fractal Design Define R5
21.5 inch Monitor
Here's the link: http://uk.pcpartpicker.com/p/6PsYhM
Edited by colonel_mortis
Cleaned up formatting
https://linustechtips.com/topic/288470-new-system-build-please-help/
get the i5 4590 with an alright motherboard
it ill be WAY ahead of the 8350
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
