Anyone know where the setting to set and offest voltage/idle frequency and voltage is in click bios 2? I can't find it.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/28835-click-bios-2-question/
Bottom one: Vdroop
Top one: EIST
I'm not entirely sure what you mean by idle frequency. I think you mean EIST(Intel Speedstep) which allows your frequency to fluctuate depending on your cpu load.
https://linustechtips.com/topic/28835-click-bios-2-question/#findComment-366563
Bottom one: Vdroop
Top one: EIST
yes! that is what i mean! thanks allot for the help.
https://linustechtips.com/topic/28835-click-bios-2-question/#findComment-366763
