Weird small pixel artifacts
Go to solution Solved by Godlygamer23,
680 is faulty then.
So, I was just playing Dead Island the other day and I started to get these weird artifacts in and out of the game. The artifacts come and go as they please and it appears at random spots. It shows up no matter what I am doing. Gaming, YouTube, shopping at Amazon, or even at idle. I tried to re-install my GPU drivers and that did not help at all. I thought it was the game that caused it so I uninstalled everything related to the game and that did not work. I tried to do system restore to a time where I did not have the game installed and that failed as well. Finally I re-installed Windows 7 because I thought it was a bug in the OS. That failed as well. I do not know what to do anymore. Please help me.
Here is a link to some screenshots of the issue
https://drive.google.com/folderview?id=0B0LV9pijJ59VUUdUNDNMV0pPaXM&usp=sharing
-System Specs
CPU: Intel Core i7 3770k
RAM: Kingston HyperX Blu 16GB OC'd to 1866
Motherboard: MSI Big Bang Z77 MPower
GPU: MSI GTX 680 Twin Frozer III OC edition
PSU: Antec Earthwatts 650w 80+ Bronze
Storage: Samsung 840 Pro 128GB (for OS) and WD Caviar Green (for games and extra files)
https://linustechtips.com/topic/28830-weird-small-pixel-artifacts/
I get somewhat the same thing in Borderlands 2. Occasionally, I'll get a "river" of artifacts at the bottom.
Does it happen in other games? If not, it's unlikely it's the fault of the GPU.
You have any other computers or monitors? Making the GPU display to another monitor/TV. Or perhaps another computer displaying to the display your rig is currently using.
Right. It looks like the issue is the GPU. Any overclocks done on the GPU or VRAM?
Do you use any software to monitor the clocks?
Okay. See if the 680 is underclocking itself on both the GPU and VRAM. Do you know if the VRAM has been factory overclocked?
I don't think the clocks are the issue. I think the GPU is just malfunctioning. If you want to test your Radeon card real quick, you can do that just to make sure.
Okay.
Alright.
680 is faulty then.
MSI.
You're welcome.
