Anyone know of some nice red sleeved cables for the supernova G2 from EVGA? I was looking on overclockers.co.uk and found the nice red cablemod ones but they aren't available yet. Are the bitfenix alchemy ones that nice? Does having these extensions degrade performance at all? Been googling for ages for some that go direct into the PSU but am yet to find any.
https://linustechtips.com/topic/288291-cables-for-g2/
http://www.evga.com/Products/Product.aspx?pn=100-CR-1300-B9
Edit: Trying to find where you should buy it
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914626
Check icemodz.com, it's barely more expensive than getting a kit from EVGA, and looks wayyyyyyyyyyyy better & you can customize it.
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914638
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914647
this
To add onto what I said @op,  you can pick any colors you want.
Here's cables he made for me for my EVGA 1000 p2, it only cost me like $115, which is only $35 more than the EVGA cables I believe.
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914740
Does he deliver to the UK do you know? Can't find it on the site...
EDIT: Found it, thanks. I may order from him. Seems to be a reasonable price.
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914797
You could try this Dutch website, as they are showing as in stock.
They have Red and Red/Black kits
http://www.highflow.nl/modding/flex-sleeves-and-heatshrinks/sleeving-kits/cablemod-e-series-g2-p2-cable-kit-red-cm-ev2-fkit-kr.html
http://www.highflow.nl/modding/flex-sleeves-and-heatshrinks/sleeving-kits/cablemod-e-series-g2-p2-cable-kit-black-red-cm-ev2-fkit-kkr.html
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3914900
He can do international shipping, he lives in Iceland and sells to the US&Canada, so he should have no problem sending stuff to UK etc.
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3915284
I looked on the site, may order from there if I do not get mine with Icemods. Cheers mate.
Yeh just saw, thanks. Wonder if he an do 1 or 2 day shipping :P
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3916817
Ask him in his livechat, I think he's a bit over-run with orders right now from the holidays, but he should be able to help out.
https://linustechtips.com/topic/288291-cables-for-g2/#findComment-3916825
