Suggestion for Power Bar for Build?
By
Brama
in Peripherals
in Peripherals
Solved by Peter Vaughan Truslow,
I have the first one you mentioned. works well for me and the spacing is just right.
you don't really need anything special, just something with enough ports and a long enough cable of a decent gauge.
Vertinari ·
Posted in Troubleshooting0 -
AngelaHornung ·
2
NeuronButter ·
3
4
Bactraxed ·
Posted in New Builds and Planning1 -
jkb ·
Posted in Troubleshooting2 -
2
1
