Ok so I could really use some help finding a case. I need a case that would fit a 360mm rad and a 240mm rad with little to no modding. I also would like a clear windowed side panel. The mobo i would be using would be an atx board so I don't want it to look really ridiculously small in the case. Thanks for the help
https://linustechtips.com/topic/28796-water-cooling-case/
The Switch 810 Window will be able to fit 360mm and 240mm radiators.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/28796-water-cooling-case/#findComment-366120
