I put up this build for tips on what to use. Eventually I got the thumbs up from everyone but I just saw Linus' video on "bottlenecks". Is my GPU being Bottlenecked? And if so is it worth switching to a different graphics card? Thanks!
http://pcpartpicker.com/user/ClubGaming_/saved/93rtt6
https://linustechtips.com/topic/287938-is-my-gpu-bottlenecked/
No, that CPU is plenty powerful and will last a few years. No need to worry.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/287938-is-my-gpu-bottlenecked/#findComment-3910496
Should be fine, if you want to tell look at how much GPU is being used and how much CPU. GPU isn't near 100% but CPU is then it's bottlenecked.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/287938-is-my-gpu-bottlenecked/#findComment-3910498
if you watched the entire video you would know that everything being bottlenecked no matter what
but this looks good
Yeah I heard that. I was just afraid of a crazy bottleneck like my gpu running at 50% or something like that. I mean it is 100 bucks more expensive.
https://linustechtips.com/topic/287938-is-my-gpu-bottlenecked/#findComment-3910547
That's totally normal. Theres nothing to worry about
https://linustechtips.com/topic/287938-is-my-gpu-bottlenecked/#findComment-3910678
