if it's something like this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256063
where it can output one of it's rated power on the 12v rail,then you should be able to put any gpu in it,up to a 780,provided you don't overclock or have a ton of HDD's/fans/lighting (which wouldn't fit in that case anyway)
at max load,which would never happen,it'd be fine,but I still wouldn't overclock.
4770K - 65 watts max (guru3d idle subtracted from load power cosnumption)
GTX 780  268 watts max (furmark)
HDD - 10 watts
SSD - 3 watts
DVD drive - 10 watts
AP141 fan - 3 watts
so the max would be ~360 watts with a GTX 780
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
