replace cherry stabilizers with costar stabilizers?
Go to solution Solved by Guest,
Cherrys and Costar unfortunately need different cutouts for the stabilizers.
So it does not work that easy, you would have to modify the plate.
Normally it is enough to desolder only the stabilized switch to be able to remove the stabilizer wire.
Hi, so I wanted to mod my stabilizers on my quickfire TK recently and could'n get them back together afterwards.
Can I just replace the cherry ones with costar ones from WASDkeyboards or do they require a different cutout in the metal plate?(http://www.wasdkeyboards.com/index.php/products/keyboard-parts-1.html)
Also, how would I go about removing the stabilizer bars from the cherry ones from the board? they are between the pcb and plate, so I can't really think of a way to remove it other than desoldering every switch which I don't want to do.
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
ok thanks, guess I wrecked the stabilizers on 2 keys of my keyboard after a few weeks, good job me XD
#KILLEDMYWIFE
  • 2 years later...
