Ok.  so acrylic is the actual waterblock; the block which water will travel through.  Nickel is simply the metal used on the direct contact of the block to the chip itself.
I looked up Acetyl/Acetal, they are different, I am a history major, so I didn't understand any of it/ what those are.
More than likely the most common metals used on the direct contact portion of a water block would be nickel, copper, etc.
There won't be significant performance differences, get the one you think looks best.
to help you out:
nickel is actually a copper base. it is nickel plated to prevent tarnish and
exposure to corrosion. most block manufacturers use copper base. avoid
aluminum blocks as they are not as thermally superior to copper and tend
to be masked as nickel. the other listings of materials are covers or plates
to beautify the blocks. acetal, acrylic, POM are usually cover pieces and
not to have anything to do with the actual cooling.
