I wouldn't worry too much about cooling as it's really not such a huge issue.
/Although an AIO would be best due to the lackluster case airflow.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888423
I have 3 120mm NZXT stock fans pulling from the front, a slim 140mm from prolimatech running PWM and exhausting out the back and a corsair H105 in push exhaust out the top running on PWM.  I have a PNY GTX760 OC that blows around 75 degrees when gaming, but the case cools relatively well.  You could only have the top as an output and the rear as an input, but then all the heat would go to the radiator, not cooling your processor effectively
You dont need an AIO, but the intel stock cooler is not an option.  Mine got so hot with my overlocked 4670K, the side window started to bow out and warp from the heat.  NZXT sent me a new side panel free, but something to consider.
My suggestion would be to get a 120x120 or 140x140 radiator exhausting out the top or intaking from the front and then other fans doing normal airflow from wherever.  Gives you more options if you dont want to exhaust on the back.
I used my old EVGA GTX285 with its thermal limiters off to cook an egg once.  ONCE.
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888500
AIO cpu cooler mounted to exhaust out the top.  Or just put 3 120mm fans exhausting at the top and go full air cooling.  air flow is restricted in the h440 but still decent.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888508
wow thats a lot of heat.  very nice they sent you a replacement!
PC Build
Desk Build
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888512
Yeah their customer service is amazing.  also got a couple of stock fans after they started humming.  No hassle, nice people, fast shipping, no questions asked.  Now i wonder what will happen when my case goes out of warranty.....
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888550
im considering to front mount a h105 as intake
and then exhaust fans in top
would that be dumb ? ^^
not dumb, no.  it will raise your internal temps, which means GPU will either run hotter or fans spin faster, or a little of both.  You can always switch it around if you don't like it.
if your motherboard supports it, you could install one of those little thermo-coupler sensors to monitor internal temps.  my Asus sabertooth came with one, but I think that is fairly uncommon.
but really, with a good amount of airflow moving through the case, I don't think internal temps will increase more than a few degrees.  that's my guess anyway.  give it a shot and let us know how it goes.
PC Build
Desk Build
https://linustechtips.com/topic/286380-cooling-options-for-h440/#findComment-3888652
