Hi guys,
Got a little bit of a problem with my front panel usb 3.0 ports, usb 2.0 work fine. Every time I plug in a usb stick or hard drive they read and write fine but when I wake or start the pc with either connected they don't read or write properly like the files are corrupt.
I think I might've damaged the USB 3.0 connector on the mobo as I've unplugged and plugged it back in a couple of times and it still happens. Could I be right?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/286315-front-usb-30-problem/
cant remember how to acess it, but try going to devicemanger or something similar(as i said, cant remember where) and check if they show up, if not, its probably the mobo connector.
googled a little, its called "COM port manager" or something.
lets hope its not the mobo :P
EDIT: read it again, its not the mobo connection..
Cpu: Intel i7-5930k Mobo: Asus Rampage V Extreme Ram: G.skill Ripjaws 4 4x4gb 2666mhz Gpu: Gigabyte GTX 970 G1 Gaming
PSU: Evga Supernova G2 850W Storage: Samsung 850 Pro SSD 512gb Case: Phanteks P400S CPUcooler: Corsair H110 OS: Win 8.1
https://linustechtips.com/topic/286315-front-usb-30-problem/#findComment-3888175
All of the USB drivers seem to be up to date. It's just the front ports that have the problem. Rear seems to be fine.
https://linustechtips.com/topic/286315-front-usb-30-problem/#findComment-3888303
bump.
https://linustechtips.com/topic/286315-front-usb-30-problem/#findComment-3892198
