I will use this for gaming and know very little about specific details on computer parts. My friend is building this so any suggestions will go to him.
Is this a good PC build?
-INTEL CORE I7-4790K 4.0 GHZ 8MB INTEL SMART CACHE LGA
-CORSAIR 512 GB FORCE LX SERIES SATA III SSD
-2TB SATA III 6GB/S 7200RPM 64MB CACHE 3.5" HD
-GSKILL 16GB DDR3 1866 RIPJAWS-X MEMORY
-ENERMAX TB SILENCE UCTB14 140MM COOLING LOW NOISE PERFORMANCE FAN
-ASETEK 550LC 120MM WATERCOOLER
-CORSAIR AIR SERIES AF120 PERFORMANCE EDITION 120MM HIGH AIRFLOW FAN
-BLACK LG 24X DVDRW
-CORSAIR RM750 80PLUS 750W FULLY MODULAR POWER SUPPLY
-SUPERCLOCKED EVGA NVIDIA ACX GTX980 4GB
-Roccat Tyon
-Corsair RGB K70
-Logitech C920 USB HD Pro Webcam
-Blue Yeti Mic
This is just the first draft so any suggestions please comment
Taking Falling to whole new Heights
https://linustechtips.com/topic/286070-help-with-pc-building/
Can you not repost?
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/286070-help-with-pc-building/#findComment-3884777
if you need to lower costs, get an i5 4690K instead and 8gb of ram.
Id swap the mic for an audio technica AT2020 USB, its a much better mic than the yeti. (looks better too!)
https://linustechtips.com/topic/286070-help-with-pc-building/#findComment-3884788
