Ive recently built a new computer and it has been running fine for a couple of weeks.
The other day it just randomly crashed, and from there on, it just keeps crashing all the time
Idk what it could be although i suspect ram issues, im not an expert but i heard ram can cause crashes.
My Specs:
Zalman h1 Case
Asus Crosshair v Formula Z Mobo
Amd 8350 Cpu
Cooler master nepton 240m cpu cooler
16gb 2133mhz Amd Gamer Ram
Xfx r9 290 Gpu
Coirshair rm650
Samsung evo 250gb SSD
https://linustechtips.com/topic/286046-help-computer-keeps-freezing/
run with one stick and see if it will freeze
run MemTest86
check your CPU temps with HWMonitor
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
