I use a Blue Snowball with a micarm etc. I always uses push to talk but now it is just to slow i need to use  voiceactivation, but i won`t find a settig where you can`t her me clicking typing etc  and  heare me without me yelling or cutting of in middle of the sentence, when i lower my voice.
I thought of a modmic  withm Audiotechnica M50 would be finde but just not using my other stup would be kind of a shame
Has anyone suggestions? How i can lower the sound of my keyboard, a corsair k95 first gen, and i like to hammer it pretty hard while playing wow
https://linustechtips.com/topic/285662-mic-problems/
Getting more quiet keys, and you could try putting a mat under the keyboard. You could also try elevating the mic from the desk, so like a stand attached to the wall or a shelf
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/285662-mic-problems/#findComment-3878517
I don't know if that microphone has the option for it, but make it pick up sound in a "unidirectional" way and make sure it's pointed at your face/mouth, that'll help immensely.
Hardware: 4790k @ 4.6 GHz w/ H100i - MSI GTX 970 - Define R5 - MSI Z97 PC Mate - 840 EVO - G.Skill 2x4 GB
Peripherals: G402 - ATH-AD700x - Asus VG248QE 144 hz
https://linustechtips.com/topic/285662-mic-problems/#findComment-3878524
