How To Improve Cooling?
Go to solution Solved by Peter Vaughan Truslow,
that motherboard will give you a space between your two GPUs which will help with your temps
Hey guys, I've recently bought 2x970's from MSi to run in SLI, and I was wondering how I could improve my cooling.
I'm about to buy a Noctua NH-D15 to replace my stock CPU cooler and for the rest of my cooling, the case I'm using is the NZXT H440 Mid Tower, I've got 3 intake fans that are 120 mm (stock) at the front of the case, 2 140's at the top and a single fan at the rear (All of these are White LED's from NZXT).
Do I even need to upgrade the cooling for the SLI? If so how would I go about doing it without blowing the budget?
https://linustechtips.com/topic/284683-how-to-improve-cooling/
either send me a link to your card or take a look at it. if it looks like 1-3 case fans with an weird shroud, it's an open fan. if it looks like a hampster wheel, it's a blower
http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1692&products_id=29086 That's the card, currently away from my PC
https://linustechtips.com/topic/284683-how-to-improve-cooling/#findComment-3864795
It'll probably be fine in practice. But just for accuracy, this is an open fan cooler. The 970 isn't too bad, but hotter cards in SLI/Crossfire (like the GTX 480/580 or R9 290X) would definitely want ventilation close to them, either with a front or side panel fan.
https://linustechtips.com/topic/284683-how-to-improve-cooling/#findComment-3865329
In that case(pun intended) you could just run as is. You should be fine what motherboard and CPU are you using?
http://www.pccasegear.com/index.php?main_page=product_info&products_id=27940 and http://www.pccasegear.com/index.php?main_page=product_info&products_id=27534
No OC as of yet, may do it in the future.
https://linustechtips.com/topic/284683-how-to-improve-cooling/#findComment-3865330
