I was changing the location of my documents folder from my SSD to my hard drive but instead of changing the location to within the hard drive I somehow managed to make the hard drive the documents folder. Is there anyway to undo this change or to be able to change the location of the documents folder. When I click on "properties" of the documents folder from the sidebar, the HDD properties come up (see picture). PLEASE HELP  :(
Any help would be greatly appreciated,
Thanks.
https://linustechtips.com/topic/284307-folder-help/
Open Window Explorer and right click on Documents in the Left Pane, you can change the locations there.
https://linustechtips.com/topic/284307-folder-help/#findComment-3858807
Thanks but I have somehow made the hard drive the documents folder and when I right click on the documents in the left pane it brings the the hard drive properties.
Right click on Librarys and select Use defaults etc. Its second option anyway. (Problems when using localized windows :)) Another thing you can try is go to location tab you see in pic and select right location for folder.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/284307-folder-help/#findComment-3866307
