Corsair RM650 rubber cables?
79wjd
Does anyone know if the RM650 uses rubber insulation in the cables, or is it some kind of plastic?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Probably some sort of rubber. What's the actual question that you want to ask? Doesn't sound like a big deal to me.
who cares...
Mineral oil and rubber is a no go, so if it uses rubber insulation then I'm going to have to replace my psu (or get replacement cables -- but the former will be cheaper -- well, possibly cheaper...it depends what route I decide to take).
Or possibly swap my EVGA G2 750w in instead since I'm pretty sure that one definitely doesn't use rubber insulation (although, I don't exactly remember about that one either).
PSU Tier List | CoC
That's quite a chemical question. And i should know the answer since I'm a chemist, but i don't. :P
Have you tried just googling your question? :D Maybe you could even write corsair about this.
At least I'm bumping your thread if i know nothing, sorry. :D
who cares...
Well, I already know that rubber in general isn't really something you want to be putting in mineral oil; but I guess there is a chance that Corsair uses a very minoot (minute*, I know, but I disagree with the spelling) amount of rubber or some type of "rubber" thats not reactive to mineral oil I guess....
PSU Tier List | CoC
most, if not all, use a plastic insul-wire that will eventually degrade in mineral oil.
as the specification when using the insulation wasn't being submerged in petroleum
products. mainly heat, high humidity and fine particle dust. eventually what would
happen is the insulation will crack and possibly fall apart. not a good scenario
to look forward to.
to really do it right, you'd get a custom wire set built for the need if going to be
permanent.
to look forward to.
permanent.
Any idea as to how long that eventual degradation would be as going with full custom cables for either my G2 or RM650 will more than likely push me out of my budget.
PSU Tier List | CoC
dunna know, i think luke said his lasted some years, but when broken down the
harnesses were brittle and cracking. so as said, if using it as a permanent PC,
look to making sure the parts are tasked for mineral oil usage or risk damage.
Most wires used in computers these days use PVC plastic for the coating. I hope that helps.
[MAINFrame Customs Shop] | [Sleeving Guide Videos] | [Sleeving FAQ]
[Project Log]:[ Katharos ]: April MotM Winner | [Project Log]:[ Xýlo Kai Chalkó ]: Working | [Project Log]:[ Aspros ]: Done - 4th Place PDX Lan |
[Reason I Live]
welcome back! hope all is well and ready for the new year..
PVC wires are usually junk, hence being banned from use in anything that is regulated (aircraft, spacecraft, ships, etc) or in tough environments. The reason they are prolific in computer usage is because its so cheap to fabricate and sell. What you need to resist mineral oil is aircraft/spacecraft/marine-grade wires that specifically are designed to withstand all sorts of nastier stuff than mineral oil (Skydrol, Jet-A, Ethylene Glycol, etc).
I would recommend PTFE or FEP with Polyiamde tape...However, this just makes the wires last much longer when immersed in oil but not indefinitely.
Also GO ILLINI! (Aerospace Engineering '10)
Thanks man, yea last year was one of the worst personally for me - but we are all coming under a new name and ready to kick butt and take names.... persay haha
Also very good info to know ^
[Reason I Live]
So it sounds like I'll need a replacement cable set regardless of which psu I use (for either my rm650 or evga g2).
Any idea on a rough estimate for a cable set for either?
PSU Tier List | CoC
Bitfenix has some cheap cable extensions, but Lutr0 Customs is way overpriced $70 for a 24-pin extension
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
i would need replacement cables not extensions.
PSU Tier List | CoC
My advice is to buy the wire and then give them to whoever is building the set. That way you only get charged for labor.
I believe we have knocked it down to 60 with the new business model.
Also our extensions are made for each system, in custom colors, and have a lifetime warranty.
[Reason I Live]
Your'e merging with modbunker???
Neat
It's kinda given away in your sig with the "Lutro0 customs shop" link
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
